Meh.
Booted my Mac Pro into Windows 7 for the first time in months, downloaded the OCZ firmware, downloaded Acrobat reader so I could view the documents.
Firmware updater doesn't even recognise that there's an SSD connected. Did the registry change, rebooted, still noting.
Booted back into OS X.
I had the same Feek.
Turns out i had to HDDErase the SSD in the end for the firmware updater to pick it up, it wouldn't pick it up when it was formatted for Mac OS.
I just SuperDupered the SSD before i wiped it, updated then restored the backup.
I run SuperDuper! daily anyway so I could always boot from my SuperDuper! backup to do it.
It appears my drive has version 1.10 so it's quite out of date.
I couldn't quickly find a list of all changes since 1.10 but it's probably worth doing the update.
I am just getting a macbook pro 17" i5 today and am looking at getting an SSD, I am looking at either the Vertex 2e 240gb or the Crucial C300 256GB, which would you guys recommend? I read somewhere the vertext has better handling of garbage? cheers for the help!
Is it worth backing up my SSD onto another HDD, formatting it then cloning it back over? Would it be better to stick it in a PC for TRIM and update the firmware?
The HDD is Crucial M225. It's been running fine but a bit slower since I put it in about a year or so ago I think.
Gents
I was going to stick one of these into my 2010 Macbook Pro after Xmas, any know issues? I've read about using the 1.11 firmware to stop the freezing issue some poeple have seen?
Thanks
Excellent thanks, going to go for the 60gb and put all my downloads and other bits on an external drive..... got a 7200rpm in at the moment, was it a nice performance boost?
