How do I record it so it isn't MASSIVE!I use fraps btw.
then second map I said nothing, then a console msg come up with "banned for using a hack lock"
You clan tag is 'etched' onto your gun (if you buy the option). Mine is [Pain] on the M14 below. It looks better on other weapons.
That is GPU memory, not system memory![]()
locky - stick your raw vid files from fraps into windows live movie maker
it has a youtube upload tool built in
its not the best but is easy to use for these purposes.
how do I connect to the TFU server, I try /connect 173.199.79.39 but doesn't seem to work :s.
/connect feature does not work in console. you will need to find it via the browser
looks like bf2 era gfx :/
If you drop it and someone picks it up can they see it?
Thanks,
G
New settings allow 125+ fps and better images....
