Hmmm, did you use ROM Manager to flash the patch, it could also be that the zip file was corrupt perhaps? Although verification would have failed if that were the case!
About to flash mine :S
I'm all booted after patch, noice!
Now to flash my UOT mods and various other tweaks
You should set up htcsense.com![]()
So... RCMixHD is the one to go for? I am still running OD as I haven't had the time to sort my phone out.
Do I have to wipe the EXT partition when I flash the phone?
My one was a few quid on ebay and is easily modded so a cased desire fits into it as shown here:
Before:
After:
ebay, no brand, about £3 or so I paid!
Everything in DesireHD ROM is working for me now, no issues at all and the htcsense.com dash is pretty damn neat :d
As long as you have the latest Desire radio everything is fine, you should always have the latest radio!
The camera app is the DHD camera, it's the internal libraries that have been modded in from the Desire to work. Don't enable 720P, Camera will crash!
I might be Nandroiding back to Leedroid. I have noticed a few things over the past half day that I have been using this ROM.
1: Battery life. Unplugged for 5hrs 44mins and battery is at 64%
I have not done anything heavy either, just checked email and some Google Talk and that is it. High display usage @ 68% for the 1hr 5mins it says the display has been on for. The next one down is cell standby @ 6% over 5hrs 46mins.
Not too bothered about the youtube bug that much but the battery one is important, I think it's the kernel...
I've not used the latest clockworkmod recovery but it should be in there and if not then it has to be done via ROM Manager.
Alternatively the better recovery that does do it I linked to earlier, AmonRA v2.0!
