Ahh k, I was talking about single screen as that is what the vast majority use. But i agree there should be variants for the higher res multi screen users.
try 5760x1080
1gb chokes.
It's not just multi screen though. Both teams have 3d now and ATI are making big noise about 3d on their cards. Am I right in assuming you need more memory for 3d?
I have a hard time seeing how it could be slower than a 580 with 1920 SP
p) Fudzilla is reporting that the 6970 has 1536 stream processors. So, who knows...
try 5760x1080
1gb chokes.
The ever-reliablep) Fudzilla is reporting that the 6970 has 1536 stream processors. So, who knows...
http://www.fudzilla.com/graphics/item/21155-radeon-hd-6970-runs-at-880mhz
This is the only place I think AMD have gone wrong, I think most information does suggest 1920sp's, but we really don't KNOW that yet, at all, and if it turns out the 1920sp is wrong, or quite possibly Nvidia people leaking slides to raise expectations massively(which would have a huge negative impact on AMD post release of a much slower than expected card) then AMD could look pretty poop afterwards.
But then if I was in the PR department at AMD, and news that the card had 20-25% more shaders than it was going to have started becoming the expected and predominant rumour I may have someone reliable leak the real shader count. So its potential a good sign that no one has done that yet.
I still say it could just be someone not understanding the new architecture and either miscalculating the SPs based on the old architecture or using a diagnostic tool thats still calculating it based on the old architecture. So it is likely to be either 1536 or 1920 rather than any other figure.
For anything sub 2560x1600/4xaa then in general 2gb will be nothing but a waste.
