Reinstall Facebook but upgrade to the Pro version (it's free anyhow) when installing. Go to file settings and click the button that says 'Delete Loads'. Easy as that.
Stop trying to look popular by adding everyone and anyone and you wouldn't have this problem in the first place.
I don't know how to do this ...![]()
wasn't trying to look popular - added people from school when was at school, and uni and various jobs and just need to sort it out now have a new job...
It's quite simple. Go to your home page, and then click the 'Account' button in the top right, a drop down menu should appear and click 'Account settings'. There should be an option near the bottom that says 'Defragment', another that says 'Reinstall'. Click the defragment one first, but if that doesn't work, reinstall it.I don't know how to do this ...![]()
I don't think you can delete more than 1 at a time. Ignore all the re-install facebook posts, it's just the geek humour coming out on here![]()
Just uninstall it like you do any program, start menu, control panel, add/remove or uninstall programs, then click facebook.
Is it there in your list? Maybe post a screenshot if it isn't![]()
Format c:
Has anyone really been far even as decided to use even go want to do look more like?
