*** The Official HTC Desire (Bravo) Thread! ***
There's still a point, we won't see Gingerbread on Sense based ROMs for a while yet. HTC hinted at an official release of late Jan~ although some think early Q1 2010 :S
No hay, I'll jump back to Oxygen when stock Gingerbread is released over the new few weeks latest.
Make sure it's definitely Leedroid 2.3 you've got too!
I have not flashed mine yet, I need to be home to reflash the partition table but will confirm in about an hour to 2.
Perhaps a silly question. When I wipe the card before installing a new rom, does that get rid of the partitions I created?
No need to wipe the sd card, just the system/cache data (factory reset) data and dalvik cache from recovery.
If you've already wiped the SD card then your data is likely gone unless recovery can be done using freeware tools.
hmm forced closure on first boot,caused by gallery 3d.......
Did you read the Leedroid release notes? :p
It's a known bug (one of 2) being fixed tonight, for now there's a Gallery3D apk which you manually update with to fix the problem.
It's not the data I'm fussed about, I was wondering if would have deleted the partitions I had set up. I always backup and transfer to the laptop before flashing a new rom now, after the first couple of times of trying to remember what apps I had downloaded :(
coming soon to oxygen (yay)
Oh no. Dont need it :(
Not sure that I'm up for a non sense based rom yet. Mot people seem to be liking LeeDroid at the minute, is their anything else I should consider?
just been farting around with leedroid 2.3, been causing me a few headaches but think im getting there, on the past leedroids and every other rom i can think of my yahoo email accounts were as simple as entering my email address and password, clicking next and voila it was automatically set up, no longer :( and i didnt know the settings to put in, fortunately found them through google but was a pain, then touchdown wouldnt install, i tried touchdown for android 2.x kept failing, touchdown for android 1.x installed fine. wtf....?
