what does cobble look like in that mod?
New overhead map view of the world.
WARNING Its a 50MB image @ 15818x10880 size
My software can't handle changing the .png file to a .jpeg with a image this size.
Cartograph also can not handle world save file the size of 146mb so I had to find a new program to make the map. Also found a image hosting site that will host a image of that file size.
http://dl.dropbox.com/u/16896597/output.png
You may want to make a cup of tea & drink it before you come back to see if it's finshed downloading.
Whitelist updated
new update out?
I have cleared the spawn of the 8bit toons and moved them to /warp 8bit , they were blocking to much out.
The spawn has been cleared and is just blank land ready to be built on I have removed the /protect on the land.
So if we can have some good builders please to build something good in its place.
A main train station was metioned as well as the builders names of tefal and topsticks.
The server now polices its self now thanks to the bb mod, its now up & running.
A santas grotto, I thought that was what you had been building for the last month
No Christmas Decs sorry
Huge Baubles is best I can do or a tree.
I just tried to light the spawn area up with a little grid of torches till someone figured out what to build there but a few of them just seemed to disappear after a while?
Careful though it just turned ngiht and there's mobs spawning there now.
^ what mods?
I've manged to find a mod for single player which lets you use commands like in multiplayer /home etc. BUT i can also summon items too which takes the fun out of it which im not going to use. I just hated the fact that if i died i kept on having to find my house again and walking/swimming for 20mins
solved
been scouting for a while to find an isolated island (singleplayer) so i can just build from scratch what i want it to look like... anyway to get a decent map mod which is live? & get a position code?
), then realised my new build is going to run into sea if I keep building in that direction
gars can you make individual mob spawns, like a spider spawner skeleton spawner etc?
Garsands, can you mass-replace blocks? I'd like to build a few (big) domes, but it would be loads easier if I could build from dirt and then you replace with glass![]()
ooo, I'll get to work designing and building a stadium then![]()
