My recent system build had a slightly bent pin and it still worked , but it was showing 4GB of RAM instead of 6GB of RAM.
So i bent the offending pin back to position and not having a problem since.
Interesting, thanks for the information.
Just to clear this up, this protection only applies to credit and store cards, NOT debit cards, cash spending, using cheques or charge cards. Therefore you have to use a credit card to be protected.
As i've paid via my Barclays Visa Debit it seems i dont have that protection.
at the bottom there's a bit about visa chargeback although with the price being 400 it might not apply.
Extra heat (Well within specs!) can move the pins, so pins which were only barely touching start moving under load, and then skip off the pads. Repeated thermal expansion and contraction can move it microns at a time, never going back into quite the same place!
<snip>
So OCUK is unwilling to even consider the fact that it might have:
A) Been damaged in shipping.
B) Been damaged by OCUK - you have after all removed the CPU from it's socket to take photo's and it could easily have been damaged during this process.
C) Slipped past your quality control and may not have been tested at all.
If it wasn't damaged by you and OCUK are saying it wasn't them then the fault lies with the courier, that being the case the responsibility is still OCUK's, not yours, get on to consumer direct about it.
http://www.consumerdirect.gov.uk/
i wouldnt go as far to say they are facts, more guesses.
A. the courier would have had to open a sealed package, bend the pins and put it back. that is very very unlikely
How is it the fault of the courier? I think it is safe to say that it would be impossible for the pins to be damaged in transit with the CPU and heatsink compressing them. You'd have to have some serious damage to the retention mechanism which would be easily visable for the CPU to come out of its socket with the HSF on top of it.
if you wish for me to move the thread to the private customer service forum to save embarrasment then please let me know
The board would not work in this condition. you mention you had it working.
The Radon bundle you sold me wasn't exactly "sealed", there was a bit of sellotape over the box, motherboard box was unsealed too with the processor seated.
B. the pins were damaged and the board didnt post. we see this time and time again. curious customers taking the cpu out for a peek. it could not have been easily damaged by simply removing a cpu.
C. i personally do all OcUK bundles. they are quality controlled by a technical manager before leaving the building. each item is individually scanned off as functional before the consignment can leave. our quality control is tight for a reason, so we are protected agains claims such as these.
If you want to believe the OP and OCUK who's left?
