I'm currently fairly satisfied with my PS3 running with the fan controller mod I sourced through Ebay (though have been spending several hours researching how I might build my own PWM controller!).
At present the exhaust air barely gets warm, but the fan does run *quite* fast, it would verge on annoying whilst playing a movie. But I want it to remain healthy while I embark on some lengthy GT5 sessions from tomorrow
In addition, because I have Remote Start (PSP) enabled, the fan doesn't slow down when I turn the console off; I am using this to my advantage by powering off 5 minutes before I leave the room, allowing the system to fully cool, then flipping the switch at the back of the console.
In addition, I got a very useful reply from the Ebay seller on the circuit design of the mod:
..so I have asked them to send a version with the 33k resistor, as I am assuming mine might have the 44k one in it. Alternatively I could make that change myself, or insert a potentiometer in there so I can vary the 'boost' applied to the speed - this would be my preferred solution, even more so if I can locate it in a way that allows me to adjust from outside the case!
Alex
"The chip itself is not programmable. The circuit is a "pulse-stretcher" which takes whatever signal the ps3 is sending to the fan and makes it longer, and therefore the fan faster. If the machine speeds up the fan, by making the pulse longer still, our module increases it still more so making the fan even faster still.
If the fan speed doesn't change it means the ps3 isn't telling the fan to go faster. This is a good thing as the machine obviously thinks the chips are cool enough as it is and doesn't need to try to make it cooler. (ps3 has temperature sensors in the two main chips)
The fan remains on when you switch it off (on the front) because it always did stay on --- it was just going so slow you couldn't hear it.
It is possible to make the module go faster by changing a fixed resistor on the module but this would be a bit of a job as it is buried under a thick layer of encapsulating material. The one to change (on 60 gig modules) is a 33k resistor (the only 33k one) I was putting 44k in 40 gig machines because the fans are quieter and so would take a faster speed without being too noisy. I think if you go to more than say 50 k it would be too noisy in a 60 gig machine.
It should go without saying any customer modification to a module will void the warranty."
Alex
