Phone is in FASTBOOT mode yes?
ive done it finally.
stupid android phone driver wasnt installed.
anyway its done. thanks for your help
Unrevoked will have put clockwork on, volumedown+power then select recovery?
Flash AmonRA v2.0.0 from fastboot the same way you did clockwork. It's the better recovery of the two!
So, after listening to everyone wax lyrical about Oxygen, I decided to give it one more chance last night, completely wiped everything, stuck the N1 table on, reformatted my SD card and installed.
After finally getting past the random hot reboots I was getting random f/c's on various apps and battery life still nowhere near as good as Auraxt.
I noticed the wifi bug last night when the wifi disconnected but I was able to reconnect immediately and signal was fine too unlike other people reporting poor signal hence the disconnect.
Time for Cyanogen perhaps![]()
Hmm Didn't notice that.
I'll just stick to Oxygen for now then.
I tried Cyanogen a week ago. The apps2sd is done by giving you an option in the cyanogen options menu. You can choose auto, internal, or external. I had it set to external yet still managed to fill up the internal space![]()
Not really many others. After Oxygen, every other ROM feels slightly laggy in comparison. LeeDroid is the best and smoothest Sense ROM and I'd go back to that but then I'm back at square one with Oxygen being smoother and lag free in use
I've flashed a previous vorkkernel version now to test the wifi issue. Will report back tonight.
Or possibly DarkDroid which looks equally impressive with way more features and reports of excellent battery life.
Hmmm, if that was fixed then i'd give it a go.
I want a non-Sense ROM, loving the extra RAM not running Sense and I think stock Android looks a million times better. Looking forward to your report. Is it easy to do if it works out positive?
