Yep installed graphics drivers from Acer site - DM still reports device cannot start... :/
CCC just shows the Intel GPU - and there is no context menu on right click to switch displays in Windows :/
I haven't even had mine a week and it has been replaced with a much better model.
edit: is the Win7 you get with the 3810TG 32bit or 64bit?
I did a quick rundown:
Acer Timeline 3810TG £389.99 vs Acer Travelmate 8371 £349.99
Gain
Get Windows 7
500GB HDD
HDMI (replaces docking port)
SPDIF on the line out
wireless N is no longer draft
It says 9hr of battery rather than 8.5
Better sound
Slightly smaller, 100g lighter
Lost
Fingerprint reader
Seems to have dropped the "Travelmate" name (less business notebook now)
Doesn't mention the Anti Shock protection
Doesn't mention a 7200rpm HDD
I don't know what the looks of it are, by dropping the Travelmate and business orientated side it may have got a more glossy look.
I just got the latest ATI drivers from the Acer drivers page for Home Premium x64...
But screen isnt as good on the 3810TG !
Keyboard is different too, depends what you prefer
Maybe try the ones for Ultimate 64 bit.
I am using these drivers:
VGA ATI v8.652.1
Try download these and see how it goes?
Those are no longer available on the Acer drivers pages. And they list the same drivers for Home Premium and Ultimate :/
Not sure what to do!
yes, however only normal when the drivers aren't installed correctly. you say you changed the bios to switchable? maybe that had some effect on it?
i would say uninstall all the ati drivers, restart and do a new install with either the ones you have ore the ones from e36Adz.
when running on the intel GPU you shouldn't see the ati card in device manager, when running on the ATI card you should see both
VGA ATI v8.652.1
**** FIXED IT!! ****
http://www.megaupload.com/?d=6GYK3ITY
These are version v8.652.1 and specifically for Windows 7.
After installing these, the device started working and I got the switchable option on my right click! SUPER!
I also can't find a price anywhere near the £350! I might steal the other one I ordered for my brother
