Is there any way I can stream my movies from my pc to the iPhone? Or even put movies on the phone without using iTunes?
Guys, does the iPhone become very laggy when the it's nearly full GB wise?
I've noticed mine become so slow over the past few weeks and I can only put it down to using the whole of the 32gb just about
whats the problem with using itunes?
download VLC Media Player, and in itunes find the app tab, and open a film and save it to VLC folder, the film then plays just fine.
Or do you not get on with itunes?
Anyone had problems with the proximity sensor? Majority of calls end up hang up on someone, putting them on hold, muting my end or even hanging up then calling someone else.
Getting really annoying but its JB and all customised so I'll have to restore before I take it to Apple, just wondered if anyone else had had issues!
I use iTunes all the time. I thought I'd have to convert all my films to whatever iTunes uses for video though?
hmmm, I have that but it is white. Unsure why my wi-fi is not working then, I have set it all up :/If youre using wifi you will have this at the top of your screen:
Ok thanks, my Wi-Fi seems to be extremely slow, I mean i'm trying to install the free brothers in arm app and it is taking well over 20 minutes now.Yes it will be white, just the shape I was referring to. If you see it, its using wifi. Anything else: o E or 3G then you're using cellular data, and you will notice due to speed of net access too.
Hope that clears that up :>
C.
