- 5 Dec 2010
Just flashed my HIS 6950 with the HIS 6970 BIOS worked perfectly. Running stable and surprisingly cool in Furmark.
Just got my HIS 6950
I've put it in my current rig, I won't flash it as my current cpu is holding the card back anyway. I'll flash it once I have my new computer sorted. And then i'll put up some benchmarks.
Can someone with a HIS 6950 which has flashed with the HIS 6970 BIOS post idle and load temperatures before and after flash.
did you increase the voltage?
well i successfully flashed a HIS using the batchfiles downloaded at techpower up
not sure what bios it used to be honest as i had a sapphire and a HIS one in the folder
ive ran furmark,heaven and 3dmark 11 without issue
idles at 38C and load at 78C
gunna fire up BC2 now and enjoy it
btw , this "PowerTune slider to the +20% setting" is it actually needed ?
You mean the batch script? I'm not sure.
But i do know for a fact using atiwinflash will work, just follow the instructions in the OP of this thread and just use your modded.bin file instead.
Well I suck worse than easy when doing this sort of thing which is why I used the "noob" package form techpowerup, just one click and its done. i found the modded bios that in atiwinflash called "unlock.bin" and thats the actual bios thats installed in the card when its flashed. I reckon that bios can be removed and replaced with your bios (the one that leaves the overclocks and Vram timings alone). I just need to identify which of the files in that techpowerup package is the actual bios so I can rename it and copy it to the atiwinflash software. I'm assuming, and please correct me if I've got this all wrong, I should be able to run the noob package and load the new transferred bios which repalced the original.
where are you getting these modded bios from plz ? i wouldnt mind trying one with higher fan speed options![]()
I'm not sure any of the bios have increased fan speeds although I think you can edit them in RBE. I used MSI to set a custom fan profile on mine which is working really well.
