thats because your ocing it a lot..And a 570 easily beating 6970?
the 6900 series doesn't have software to control the voltage yet, so we are limited
They both run 930core at 1.087v when in single mode, but SLI requires 1.125v to get them stable together at 920core. I have BIOS modded both to allow voltage past the 1.087v limitation.Nice. What volts you using for that 920 core clock (I'm at 1.050 for 875)?
Heres my score: 6950 flashed to 6970 at stock speeds
my oc isn't heavily. stock core clock is 890, thats only 50mhz oc.I'm using stock voltages, and that '6970' I was comparing to was also heavily oc'd
nobody is arguing ok.. don't make something out of nothing..
