I get an odd shimmer/ripple during 2d apps and in game movies well at least in the Witcher is this the drivers or because I'm running it VGA and not DVI so a clock/phase issue?
Do the Lagom LCD test.
http://www.lagom.nl/lcd-test/
Right right...so I just just use reset and and save that as the 2D profile?![]()
Wait, what? That's not how you do it
Set 725/1000 and standard voltage as your default profile (2d profile) and that will downclock to 157/300 at 950mV in idle.
Set whatever your overclock is as a 3d profile, that will kick in any time you launch a GPU-dependant application.
Side note: be aware that minimizing a game and trying to watch a youtube (flash) video with Hardware Acceleration on will result in an instant driver crash as it's supposed to downclock (or overclock for that matter) to 550/900 or something along these lines. That's a software limitation though.
In other news, my card is unstable with memory at 1150MHz or above. Can MSI 5850 Twin Frozr II owners check their max memory overclocks? Do the tests with core speed and voltage on default, the memory clock is independent. I think all cards use the same memory modules thus finding the max stable ones a good indicator of components quality.
Reference memory usually hits something in between 1200-1250MHz before it crashes/throttles back.
Can someone give a me a beakdown how to overclock this.
I havnt overclocked a card in ages. So dont wana blow this up... By reading most of this thread some people are having problems.
Thanks
Edited: Got it working now working at 157/300MHz at idle now lol
As for the memory, that for most game 1200MHz memory clock is no problem (I play on TF2, L4D2, Killing Floor etc), but in BFBC2 it doesn't like that memory clock beyond 1100MHz for some odd reason...and it would crash if the memory clock is higher than that...
Did the Lagom looks like my monitor goes out of phase as auto corrects it then it creeps back out again. Would running it through DVI solve that?
Well, while the memory may not clock as well as hoped for, I still think I'm quite happy with the card, considering it only costed £125Great, so you got it working right
TF2/L4D2 - Source games. Not really GPU demanding, are they? Try Crysis or any other graphics hog, you'll immediately notice that it's not BFBC2 issue. These cards have very low quality memory modules it would seem. 4.4Ghz vs 5Ghz on Asus cards isn't impressive. Worse than that, reference MSI cards got better memory modules on them.
flashed mine, seems ok, not saved my fan profile i edited though
