I received my P8P67 Pro with 0402 BIOS and first thing I did was update to 1053 beta.
The AutoOC does go through a number of posts where the mobo is tinkering with settings to get what it thinks is a good OC. If you let it run enough it eventually posts, it is however not very good in terms of what it achieves.
Mine was dieing but once I bumped the DIMM voltage from 1.5v to 1.65v I had no issues with my ram at 2133MHz.
I'm running my 2600k at 4.6GHz and 1.25 volts. It idles at 32deg C and on load circa 47 deg C which I'm happy with since the case needs quite a lot of cable management work yet. Not bad for an SLI setup crammed into a Lian-Li PC-A05nb.
Overall very happy with it. Lots of tinkering required still.
Hopefully Asus will keep BIOS updates coming to play with.
