- 10 Jul 2010
- Gtr London
Just include screen shots of the problem if possible, and include a note with the exact problem. There's no way on earth any card should be idling at nearly 90 celcius!
Hi I know it doesn't matter now but if you check here - http://imageshack.us/content.php?page=uploadersorry for the huge image, i can't seem to resize it. temp is the red number at the bottom right
Download that program, then when you upload a pic you can change the resolution before uploading it to 320x320 with a click of a button.
RMA THAT CARD.
i had the same problem with my new 580 had to send it back and get a new one was very annoying
'all i was doing was checking emails'
lol
If a reboot doesnt sort the problem, then yea, I think the card is busted.
Ok card doing 5fps and is running at 106 degrees in heaven benchmark
Did you want a replacement or a refund? I would rather get a refund and switch camps to Nvidia
Why? its clearly not supposed to run like that. You do get one offs with defective products. Not even Nvidia are perfect.
Edit: i think within 28 days you can get a refund (dont quote me on that) but after that they can either refund you or replace it. You could probably have the value against a different card tho (Depending on age)
What sort of fan speed are you getting at 100C?
Does the fan speed change at all under load?
