Its a utility room? Doesn't matter what it looks like in there tbh, it's behind a door and not seenMoney saved there is better spent in the rest of the build.
I missed that, the kitchen sink is also stainless though
I missed that, the kitchen sink is also stainless though![]()
I think he means integrated into the units mate, as to hide them
Still EVH, Why no proper 17th edition consumer unit?
I like to think I take criticism on board, so with that in mind I changed all the sockets for a 16A commando socket. This allows me to have a surge protector in the rack. Needs a quick coat of paint to cover the filler.
Indeed, I do
EVH! Looks amazing! More Pics though dude
I want to come over for a cuppa![]()
I get the impression that he means integrated into the units, with matching door fronts covering them
EVH - Fantastic job getting this far, what a journey, i am a big fan of that fridge too. Good job changing the rack supply to commando too.
My only thoughts/critisism's are re the appliances and fittings in that i do agree that higher end integrated appliances may have looked smarter, as would a porcelain kitchen sink rather than a stainless.
As i say though, very good job indeed fella.![]()
Hmm wont you have an issue opening those doors on the corner cupboard there. Unless that is a 900 L Shaped corner unit the handles will knock into eachother and you wont be able to open the doors fully...
Looks very nice however!
Not sure, I'm not an electrician so whatever is in the house was his decision (apart from the commando under the stairs).ZG002 said:I think he means integrated into the units mate, as to hide them
i'm missing something there then :s
1) Lift metal bars off
2) wipe with damp cloth and some dettol
3) put metal bars back on
4) done.
What's wrong with the consumer unit?
I'll post a picture of the finished board, for your interest then.
Also, perhaps you can double check my method for the commando socket.. the original sockets under the stairs were on their own ring main. I took off all the sockets and was left with 2 twin & earth feeds, "send and return" I assume.
When wiring the commando I've just put both lives together, both earths and both neutrals in to the appropriate connections. Now, in theory this works because the boiler is on the same ring and that's running dandy.
Ok?
I'm trying not to post in the thread unless I have pictures, so apologies to those who are subscribed now.
Your welcome to come over. Getting here may be a problem?
and I wouldn't worry about it lol.Right, So the doorbell has no RCD protection (not needed as transformer is in CU there by the looks)
But say you had a fault on one of your in built appliances in the kitchen, Neutral earth fault.
That would knock out your 2nd RCD. Which in turn would knock out your Lighting in the whole house.
Id of split the lighting, One on the first RCD and one on the 2nd RCD. Sockets I'd of probs split ground and first floor to one on each also. But that's not too much of a problem.
The whole thing will probs never be an issueand I wouldn't worry about it lol.
