- 27 Mar 2004
- Between Realities
So if I buy a PSP I can't use it as a coaster?
absolute crap, if you buy something you can do anything you want to it.
1: Its against the terms and conditions you agreed to.(You consumer, not you personally)
2: the Copyright, Designs and Patents Act comes into play with regards to modifications to hardware and software. Its the very same act used to fine people who open up their virgin\sky boxes and crack them for all channels.
Using a PSP as a coaster is a bad analogy, as you're not altering the PSP in any way. You just have your cup on it.
