Its slightly overpowered though, so you can really crank it up and do some light aerobatics if you want to. Not really an idea model for it though.
I've read this thread,I dunno why but this vid has just sprung to mind!
Run in to yet another problem![]()
I need to get the exhaust of the engine, its held in by two hex screws, however one of them has rounded.
Whats the easiest way to get this out? im going to have to look at replacing it, I need to get the exhaust off as I need to cut out and fit the nose engine cover
Dremel and careful drilling?
Why does the exhaust need to come off to fit the cowling? Can't say that's ever happened for us before.
You can use card, taped on the fuse that then goes towards engine and make your template there and then transfer that to the cowling to make your cut marks.
