Who here owns a Renaultsport?
Looks nice and clean, dont like how it hasnt got Cup suspension and the fact hes using pictures taken in the summer yeah it looks shiney and bright, but its not a up to date picture of its current condition.
Considering I'm looking at buying this car I should really know what you mean by 'cup packs' which I believe is all the additional extras?
Seems to have the sports seats, climate control, air conditioning?
What am I missing aside from the suspension?
The Cup pack refers to
One Cup pack = Spoiler and Wheels
The Second is the suspension.
Not worth buying a normal Clio when you can get a FF (Both cup packs) for around the same price. :)
But saying the above, mine has both cup packs yet I have fitted aftermarked shocks and springs which are better. You could always buy a standard one and buy £600 worth of springs etc if you want to go down that route?
Unless you're going to change the suspension setup, then there's no point buying one without the suspension cup pack.
Stupid reply is stupid!
To be honest, I'm not that bothered about the wheels and doesn't this car have a spoiler on the back? How big a call is the suspension. For 4k this looks a cracking example considering it's condition from the photos and low millage?
I really am stupid when it comes to cars but when you say wheels you're referring to the tires and not the alloys right right? Surely they have to be changed at some point anyway.
Maccy, can I ask how you can tell from the pic / description that it doesn't have the cup suspension?
FF?
FF = Full Fat, just a term used to say its got bot cup packs :)
Yes it has a soiler its smaller and not the cup spoiler, IMO the cup pack tops the 182 off. Yes the alloys are a different colour much much darker. And the suspension is the killer. It is much better than a standard clio with out the cup pack suspension.
Buy one with both cup packs :) Not worth buying a standard one if you are doing no modding ie aftermarket suspension
Hope that helps :)
I guess you missed my post. Unless you're going to change the suspension setup, then there is no point buying a 182 without the cup packs. The suspension cup pack pretty much makes the car what it is.
Think you need to do your research Gustov, it sounds like you don't know what you're getting into both from a buying and ownership perspective.
