- 6 Feb 2010
You can't just assume Crysis 2's graphic engine will be the same as Crysis 1 though...hell, even Crysis Warhead's game/graphic engine is different.OP stated that he likes playing both crysis games and is looking forward to Crysis 2 when it comes out. If Crysis 2 is optimized for PC and not a slap in the face console port, then the 2gb frame buffer of the 6950 will probably give better results than the 570.
Crysis 2 is a sequel to the series, and with a different game/graphic engine, so you can't just carry Crysis 1 performance over as representation of for Crysis 2 performance, unless it uses the same engine.
The way I see...considering 6950 does better than GTX570 only in Crysis (and F1 2010), and slower in almost everything else at 1920 res points to that the 69xx card is highly optimised for Crysis 1, and cannot be interpreted as being faster as overall.
And then let's not forget GTX570 can overclock by 25% on average, but the 69xxs' overclock is pretty much maxed at 10-12% even with voltage control...
) cannot maintain a minimun of 30fps. I would argue that the 26-33fps displayed by the 6950 is not playable as well.
lower than my old GTX 285
