You can set it to off and run extreme in Heaven, the result is you run with no tessellation what so ever and in doing so fake the scores it gives.
because heaven will say that it was enabled ? as per heaven settings
well ive just gone from
FPS:105.0
Scores:2645
Min FPS:65.8
Max FPS:271.7
to
FPS:107.1
Scores:2698
Min FPS:68.4
Max FPS:272.1
that was with AMD optimised tessilation, is that the correct way or do i set it to application controlled ?
i was kind of hoping the xfire enabled logo i use when in game would have changed to AMD as apose to ATI
