Ati 11.1a Hotfix coming today
You can set it to off and run extreme in Heaven, the result is you run with no tessellation what so ever and in doing so fake the scores it gives.
because heaven will say that it was enabled ? as per heaven settings
well ive just gone from
FPS:105.0
Scores:2645
Min FPS:65.8
Max FPS:271.7
to
FPS:107.1
Scores:2698
Min FPS:68.4
Max FPS:272.1
that was with AMD optimised tessilation, is that the correct way or do i set it to application controlled ?
i was kind of hoping the xfire enabled logo i use when in game would have changed to AMD as apose to ATI
FPS:105.0
Scores:2645
Min FPS:65.8
Max FPS:271.7
to
FPS:107.1
Scores:2698
Min FPS:68.4
Max FPS:272.1
Depends if you want. For best benchmark scores set it off but then it removes the point of the benchmark.
im happy they added this option.
Now i have even more control over my Graphics :)
if i wana use max tessilation i can, if i want it off but cant turn it off in game then i can..
Whats wrong with that?
Getting driver freezing and BSOD on those ones, they also failed to show info from my 2nd card
freezing in what and bsod in what ?
failed info where ? gpuz ?
i got them from there this morning and all if fine
CCC2 has no temp, activity, fan speed or core/mem frequencies for the slave card. Also lacks manual fan speed control, with 10.12a it would allow it for about 10 seconds then go back to auto.
BSOD happened while loading L4D2 (after restart it was fine) and with the Chrome browser and two tabs open (facebook and wiktionary).
Drivers froze and reset, think that was just using the browser aswell but can't remember what exactly.
Their leaked beta's so I don't care about the BSOD and drivers freezing, just hope the 11.1's CCC2 will finally let me know whats happening with the 2nd card like GPU-Z can but with better support obviously.
Unigine (With 11.1a Drivers)
FPS: 34.5
Scores: 868
Min FPS: 16.2
Max FPS: 86.4
Heaven Benchmark v2.1
10.12's
FPS:34.3
Scores:865
Min FPS:4.1
Max FPS:88.0
Hardware
Binary: Windows 32bit Visual C++ 1500 Release May 21 2010
Operating system: Windows 7 (build 7600) 64bit
CPU model: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
CPU flags: 3465MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT
GPU model: ATI Radeon HD 5800 Series 8.801.0.0 1024Mb
Settings
Render: direct3d11
Mode:1680x1050 fullscreen
Shaders:high
Textures:high
Filter:trilinear
Anisotropy: 4x
Occlusion:enabled
Refraction:enabled
Volumetric:enabled
Replication: disabled
Tessellation:normal
Only a very slight difference with my HD5870 with AMD Tessellation Optimizer on, will wait for the officials :)
