- 7 Feb 2004
I managed to get a pressure washer and patio cleaning attachment through hotukdeals for £40 just after chrimbo so decided it would also be a good time to invest in a HD Lance and some snow foam through the Autobrite group buy going on at detailing world.
I got the Lance, 500ml of Super Snow Foam and 10l of Magifoam which is the snow foam of choice at the moment for £59.
This picture is a bit misleading as the car doesn't look that dirty but it was fairly bad.
Up close you get a better idea.
This is the second time I've used snow foam and it didn't really touch brake dust last time so I gave the wheels and tyres a quick squirt with some Viro-Sol All Purpose Cleaner and a quick brush to agitate the dirt, this can't have taken longer than 2 mins.
Car foamed up, I left it about 15 minutes to dwell, time for a quick cuppa.
You can see the foam changing colour as it draws out the dirt
A quick powerwash off and underneath we have
Spotless, although I did apply some tyre gel.
Here's a couple of vids, applying and removing foam.
The first time I used the snow foam I didn't foam a part of my car but still power washed it afterwards to see if it was actually the snow foam that cleaned it or was it just the power washing. When it was all washed and dried the part I didn't foam was still dirty so it definitely works.
so much fun! makes washing and cleaning much easier and safer for the finish.
