- 7 Feb 2004
Super Snow Foam from CYC
and medium on the lance, also from CYC.
Nilfix 130c6 or something like that. 130bar.
It will probably stick to my car now, because i think the wax has worn off, but when its freshly waxed it doesn't cling on at all it seems
How much foam do you put in the bottom, about a inch?
Also do you top the bottle up with water aswell?
My 100ml of foam and 300ml of water and the lance set to max only lasts just long enough to give the car a coating, maybe 40 - 50 seconds.
