- 8 Dec 2002
- North Yorkshire
Really? I thought the E-fused part was deliberate by the carriers?
Me too , apologies to samsung if im wrong
For the last 3 days I've had Doc's ROM v9.1.3 JS3 with Hardcore's newest kernel. K12Q.
I can honestly say it feels like I have a new phone in my hand!
I was on the V7.5 which I liked but this is another level of fast, smooth and responsive. The Gingermix theme is also brilliant and the GPS for me is way, way better.
Took a couple of hours of further reading to make sure I wasn't gonna mess anything up and deciding which bits to choose from the ROM kitchen but if you know what you're doing with phones and ROMs I can't recommend this enough!
http://romkitchen.org/
http://forum.xda-developers.com/showthread.php?t=817703
I've not tried his one. I expect the speed to be similar but Docs lets you customise it so much. Check out the Kitchen link to see all the options down to apps, themes, boot animations, non increasing ringtone.Is it better than Darkys ROM.
I forgot to mention the inclusion of voodoo sound v2, this definitely improves sound clarity for me
What's the best way to solve this problem, preferably without loosing all my data/settings?
Really don't want to have to a factory reset if possible![]()
Im on Darky 9 and idk for some reason ive been getting some weird bugs and some laggness so i think its docs a try. You said your GPS is a lot better, just wondering what modem and css your using. Thanks in advance for any help dude![]()
I'm on the JPY modem. It seems to differ for some phones but my GPS used to find the satellites but not actually lock on, now it quite easily finds and locks onto 7-9. I use GPS Test app.
CSC I picked the XEU one I think
Settings> about phone> baseband version. The last letters are the modem.
Not sure about CSC, it's much less important though
Yea, it's the reccommended one of the moment. Further reading here
any word on 2.3 yet?
Does it really make that much difference? What are they ?
