27 Jan 2011 at 08:32 #782 Yaka Yaka Soldato Joined 19 Oct 2002 Posts 3,012 Location a dark place bit too close wot are the temps when stressing it?
27 Jan 2011 at 11:19 #783 gatecrasherlok gatecrasherlok Associate Joined 9 Dec 2009 Posts 779 Location Manchester
27 Jan 2011 at 19:58 #784 {SAS}TB {SAS}TB Soldato Joined 20 May 2007 Posts 12,887 Location Location: Location: sorry about the quality ) Hmm, I did rotate them imageshack appears to have buggered them Last edited: 27 Jan 2011
27 Jan 2011 at 20:18 #785 Schizo Schizo Soldato Joined 19 Feb 2008 Posts 13,670 Location Home have you tried using the camera the right way perhaps ?
27 Jan 2011 at 21:50 #786 {SAS}TB {SAS}TB Soldato Joined 20 May 2007 Posts 12,887 Location Location: Location: Fixed! Last edited: 27 Jan 2011
27 Jan 2011 at 22:44 #787 Guitarman0 Guitarman0 Associate Joined 4 Dec 2009 Posts 1,669 Location Worcestershire ~TB~ said: sorry about the quality ) Hmm, I did rotate them imageshack appears to have buggered them Click to expand... Does the T-Junction just go to a fill port?
27 Jan 2011 at 22:47 #788 {SAS}TB {SAS}TB Soldato Joined 20 May 2007 Posts 12,887 Location Location: Location: yes mate
28 Jan 2011 at 00:19 #789 Yaka Yaka Soldato Joined 19 Oct 2002 Posts 3,012 Location a dark place ott but would using a fillport like that make it easier to drain the loop?
28 Jan 2011 at 06:45 #790 {SAS}TB {SAS}TB Soldato Joined 20 May 2007 Posts 12,887 Location Location: Location: Yeah, especially when the pump / res is lower than the rad - makes it so much easier to fill / top up or drain the loop
29 Jan 2011 at 19:27 #791 Atmos Atmos Associate Joined 27 Aug 2010 Posts 78 Just took the side of the case of and decided to take a picture. http://i52.tinypic.com/4jn9z4.jpg I'll resize it so it's displayed in a while.
29 Jan 2011 at 19:48 #792 Greg0986 Greg0986 Associate Joined 2 Sep 2010 Posts 2,050 Location Somerset will be braiding the fan cables later this week Also going to buy a 6950 next month Then going to crossfire another in July Last edited: 29 Jan 2011
30 Jan 2011 at 02:48 #793 SubScape SubScape Associate Joined 6 Aug 2010 Posts 542 Location The Internet. That just doesn't look right without the pci-e slots filled with multi gpu goodness
30 Jan 2011 at 10:34 #794 D-an-W D-an-W Associate Joined 14 Sep 2008 Posts 122 Greg0986 said: will be braiding the fan cables later this week Click to expand... Loving the braiding on the PSU connector! I know from experience your fingers end up shredded removing all those terminals
30 Jan 2011 at 16:26 #795 V F V F Soldato Joined 13 Aug 2003 Posts 21,184 Location UK What are the temperatures like with the H50 on the X4?
30 Jan 2011 at 16:57 #797 havok havok Associate Joined 14 Apr 2004 Posts 69 khemist, is it not possible to use the water cooling on the GPU as well?
30 Jan 2011 at 17:13 #798 khemist khemist Soldato Joined 9 Nov 2006 Posts 5,536 Location Earth Not with only a 120mm radiator.
30 Jan 2011 at 17:21 #799 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Yes, but not on the 120mm rad he currently has EDIT: Beaten! Note to self, REFRESH PAGES!
11 Feb 2011 at 17:42 #800 skid34 skid34 Associate Joined 14 Sep 2009 Posts 201 Location leicestershire some new fans and tidied wires up a bit
