I do that but still am running out of space, I have about 130 apps
well u will need to do one of those repartition table jobbies, guides on xda, or someone will post a link... or delete half those apps! lol i only have about 20!
s-off - you can change the boot tables really.
boot tables - basically like partitions. some give more space for system, some for data.
n1 table gives more room for data than normal, the oxygen one iirc, gives 300+ for your data, but about 90meg for your system. basically, no sense roms on that
So its really not needed then?
Just had an Windows update fail on my PC and wipe my hard drive. This is becoming annoying its a standard W7 install. Sooner I get rid of this the better.
guys anyone tried any of the test mods after rc7? wondering if there is anything new?
There have been no new test builds, don't think any more are due now, N1 OTA soon!
See how silly it sounds? Back stuff up like you would anything else.
What nonsense its done several updates without issue and then wipes the messages and fails on this one. I shouldnt have to plug it into my pc and backup everything when its OTA update should I. Upon further reading its a common problem with this update. But dont let me stop your silly analogies![]()
Obviously I will going forth back everything up from now. Seems pointless offering ota updates when I need to back up to a pc anyway but who am I to question it.
Do you still need to pay to sim-unlock Orange-branded Desires before you can run Unrevoked etc if you want the radio to work?
