Have you got your order number? I shall look into it for you.
Order Number: OC1169850
Thanks a million 5UB! Won't ask again![]()
What are your other system specs?Are you guys sure this card will be ok on a CX600 PSU? Still torn what to get my lad, this or a 560 soc![]()
edit: NVidia recommends a 600W PSU or higher to run a GTX480. As your PSU meets this spec you should be absolutely fine. However, if you intend to massively overclock your CPU and GPU this PSU might limit ultimate speeds.
So you get it early and you can't use it!
Worth waiting for though!![]()
still waitingbeen looking out of the window every 5mins, its not coming is it
Attempted delivery 7.42am, DPD redelivered midday, excellent, now to decide if I need another one![]()
Tom's conducted this test to show the consumption of s GTX480. Alongside an i7-980X processor based system max power consumption was 450W, with 360W being the average whilst gaming. As the 980X processor consumes quite a bit more power than an i3/i5, your 600W PSU should be more than sufficient.My lad has got a i3 540 @4.0Ghz, 4GB 1600Mhz RAM, 2x Samsung 500GB F3's and currently running 8800 GTX. I will step the i3 up to i5 760 at some point too so that will need to be taken into consideration.
Afterburner is the best/defacto tool for all current NVidia and AMD cards. You can get it here.What software are you guys using to overclock it?
Well, DPD said they'd deliver between 2.15 and 3.15, the delivery guy knocked on the door just as my pc clock switched to 2.15 bang on....... Freaky.
