Agreed - my 280 is inaudible for normal desktop work.
The 480 is much louder than the 280. Like fox, i trusted the reviews and expected similar noise levels to the 280 and am a little disappointed. Just thinking about whether I can live with the noise or not, but initial reactions are that it will be a no.
A £100 more for a GTX570 ?
[TW]Fox;18384866 said:Yes I have two monitors but what difference does that make to idle temps?
I've got a well ventilated Coolermaster ATCS201 with two 80mm intake fans and 2 80mm exhuast vans.
[TW]Fox;18384889 said:What else can we do but live with it? It's either that or put it on MM.
[TW]Fox;18384812 said:The same review sites had graphs showing it to be as loud as a GTX280, another card people complained was loud. I had a 280 and didn't feel the noise to be an issue. Therefore I took the information I read and thought that if it has similar noise levels to a 280 it would be considered loud but I'd be able to tolerate it.
This isn't even in the same ballpark as my 280.
Its not all about the graphs, its a combination the pitch and DB rating witch depending on what sites you read needs to be taken with salt.
Nvidia have reviewer guild lines, designed to show the cards in the best possible light.
I find it amazing how people expect a 350watt card with a 35watt delta screamer fan to be quite![]()
Any online purchase can be returned under the DSR regulations. As long as you've taken good care of everything and are happy to pay the return postage you've not lost too much
[timko];18384927 said:Does your 280 have the stock reference cooler?
New cards in this era of gpu accelerated windows, and videos won't clock down with a second monitor attached.
Try disconnecting a monitor and see how that affects things.
It's not the end of the world anyway, put a Zalman cooler on it, problem solved![]()
If the stock cooler is too loud, search for this little gem - Inno3D i-Chill Hawk Graphics Card Cooler. For 20 quid it looks great!
[TW]Fox;18384977 said:If this didnt void my warranty thats exactly what I'd do.
I'm now thinking about either a 570 or waiting for the 560 Ti SOC instead![]()
[TW]Fox;18384945 said:Well obviously its in perfect condition - it's been in use for like 30 minutes. Hmm, I guess thats an option. But where to go from here? I wanted the performance this card offers
Wow, stunning difference. It's now idling at just 43c! The fan is still ridiculous, mind.
Yes it does.
I've set a manual fan profile in afterburner that keeps the fan at 30% up to 45C and then gradually ramps up to 65% to 85C, then ramps up to 100% at 100C which is just below the cards safety threshold of 105C.
