How can they tell if people have replaced the stock cooler if it's sent back with the original?
Some firms don't use anything, but the main ones are glue, seals, void stickers.
Thread locked screws are worse.
It will use upto 350Watt stock, 400 plus if when you start to clock.
I think your talking about the GTX580, that has a throttling system once the card passes 270~.
Will it hell.....
Mines pulling about 240 watt overclocked.
No, the 480 has a max TDP of 250W at stock settings. It can go a bit higher when overclocked but the absolute max will be ~300W due to the 150W+75W+75W limitation of 8pin+6pin+PCI-E connectors.It will use upto 350Watt stock, 400 plus if you start to clock.
Right I'm back with the GTX480 installed, took me a lot longer than expected but then I realised I hadn't removed the cover on the bottom PCI slot, wondered why it wouldn't bloody go in
At the moment it's at idle and seems quieter to me than my GTX260 wasCertainly it's not very loud and is at a temp of 38C according to Afterburner. Right let's see what this thing can do and how loud it gets....
Oh by the way Afterburner doesn't seem to be showing the correct Core Clock etc, showing 51 for the core clock , 101 for the Shader Clock and 135 for the Memory clock, what's that all about?
Yes it will. All four of mine did...
The 400 & 500 series cards downclock when they are in 2D mode to save power and reduce heat. These clocks are normal.Oh by the way Afterburner doesn't seem to be showing the correct Core Clock etc, showing 51 for the core clock , 101 for the Shader Clock and 135 for the Memory clock, what's that all about?
Strange my rig pulls 190 watt from the wall idling and 430ish at the most strenuous part of vantage fill rate tests.
400 watt video cards would land Nvidia in court.
Does the two molex to 6 pin go into the motherboard or a PSU cable and power the card?
I am right in saying even though the card has 3 outputs, only two monitors can be supported by a Nvidia card?
how do you know that. do you have a plug with a wattage meter on it? would love to know what there actual name is
150W+75W+75W equals 300W max unless you modify your card. 350 to 400W is a nonsense.Nope, It has an NVIDIA ESTIMATED AVERAGE PEAK of about 250watt. It will pull upto 350 and more when clocked.
150W+75W+75W equals 300W max unless you modify yout card. 350 to 400W is a nonsense.
It's only an issue if you have two monitors, and even then I'm thinking he must have the pc strapped to his head for it to be that intrusive.
Send it back and buy a 6950 like I told you in the first place?![]()
[TW]Fox;18385856 said:Have you got yours unlocked to a 6970 and clocked at 6970 speeds?
