i am hoping GPU-Z is reporting these temps wrong.
On max temp it says 123 degrees
It shows two gpu temp sections though.
Afterburner has it at the high 60's .
Could gpu-z be wrong?
I dont understand why your fan is below 1000rpm at 30% fan and mine isnt?
If mine had the fan speeds that some of you guys did I'd probably not be nearly as annoyed with it.
How do I get my fan do do 772rpm?
