I read somewhere that the players on the xbox are more skilled than players on the ps3, is this accurate?
Well I managed to go from level 30th 4th prestige to level 17 5th over the double xp w/e. Not bad considering I was out two nights
Not sure what to make of the new maps really. I like Berlin wall but the no go area is a bit meh. You just cant go there, theres no risk reward to it so whats the point? (or am I missing something?).
This was certainly true with MW2 not sure about Black Ops though.
tbh, I have black ops on 360 and pc. pc players are much much better than console players. was the same with mw2 really also.
Stating the obvious really. Keyboard and mouse will always beat a pad. Linked with dedicated servers.
The only thing I would change with alrik's suggestion is take off hacker. And put on ninja. Better still get it pro.
I would swap care package for napalm. As care packages. Are usually rubbish!!!
Also I would be tempted to run with hardline. With the kill streaks. Suggested. As if you can manage 3 kills then die each time. Most of the time their radar will be jammed. But maybe ghost would be a good start.
If your going the silenced route. I would also suggest trying galil.
And dual mags. I would swap out for extended mags.
Ratio
I watched a few games and noticed a couple of things, firstly what sensitivity are you on? It seems to be a tiny bit too high for you at times when watching the games back. Have you tried knocking it down a level?
Also you seem to Aim down the sights a lot when people in your face, when instead you should hip fire since the enemy is doing exactly that when they killed you.
Here's a class for you to try out as well
AK-47 w/Silencer & Dual mags (silencer keeps you off the mini-map and dual mags gives you a faster reload with 150 spare ammo instead of 90)
Ghost Pro (hides you from the UAV's and airsupport which helps you survive and get the drop on people)
Warlord Pro (for the 2 attachments and extra grenades)
Hacker Pro (simply because the rest are poo, except maybe Marathon)
Killstreaks
UAV
Counter UAV
Care package
And fill in the blanks with what ever you want.
some bloke with an L96 was owning me left right and centre. I got mad and made it my mission to take him out, but every time he got the drop on me. Finished 18 - 0 and called in dogs, chopper gunner and the lot.
How can you tell? there isnt any cross platform matches, as with everything else there will be good players and bad players on both consoles.
i dont get how fast some people can be on the xbox. i simply cannot do things fast enough. aim assist doesnt seem to help and i dont seem to be improving. lucky to finish a game with a 0.5kdr
beginning to annoy me to the point of giving up.
It could be the game screwing you over, you will find even with slight of hand pro (faster ADS) other players can aim and fire faster than you can even with the drop on them, it's just the way the game handles lag.
