Is it possible to overclock these to 580 performance?
To quote myself from just a few posts up...Is it possible to overclock these to 580 performance?
I love my 480
It is idling at 38/39 degrees (34% fan speed ~1780RPM)
Clocks are as follows (i'm still in the process of OCing):
Core: 821MHz
Shader: 1642MHz
Memory: 1882MHz
Custom fan settings.
When playong MW2 (max settigns) max temp got 73 degrees and max GPU usage got to 97, i find the GPU usage surprisingly high?
What are you using which gets the temps up to 93c?
Hows the airflow in your case?
Also, 93c is ok ish thats where i would start to worry a bit really, mine on full load goes to 80c maybe 83c but thats it.
When playong MW2 (max settigns) max temp got 73 degrees and max GPU usage got to 97%
Sorry in your earlier quote it said 97 without the % mark thats where i thought it might be the temperature xD
Haha! so in reply to the original post, your GPu is fine![]()
Do these have volt control on them and is there much OC room left.
I've had mine running Furmark at 875/1750 with 1.1V, no problem. 900/1800 with 1.138 locked the system up, sadly. Possibly needs more volts?
This is with the Zalman VF3000 cooler. Temps while running Furmark @ 875 were about 82 degrees. I think my case fans are struggling to get rid of so much hot air from the cooler.
835MHz is very good for stock volts. The most I can get out of mine is 875MHz, but that requires 1.15v to run completely stably in a well cooled case.Whats the best people have had from this card with the stock cooler now? I have mine at 835/1670 stock voltage using Afterburner not tried above this so far but it seems rock stable. Not really know much about voltage tweeking so left it well alone. Dont know too start saving for an SSD drive for my next upgrade or a custom cooler for the 965BE I have a feeling that an SSD drive would be best so might get a 100 gig one in a couple of months time after everyone around heres bloody birthdays done and gone
