Got a link to the guide you used? Please.
I have googled and found guides talking about goldcards and some that don't so wasnt sure what to go by?
J
are very own Khaan! made us a guide.. simples
http://forums.overclockers.co.uk/showthread.php?t=18195985
Snip
Snip
What ROM did you flash?
You might not be able to update google voice as it's in the /system partition and not data perhaps.
I'm installing CM7 Nightly in a bit, I notice a CM7 hboot is out now too![]()
I flashed the MoDaCo r9 with A2SD ROM and that was the one that would let me update the Google apps.
How are you finding calls with that? I had terrible echo, or I should say whoever I called got terrible echo. Regardless of the RADIO image.
But i have now flashed the DeFroST 6.1a FRG83 + CyanogenMod Full Rom with a radio update as well. and this is working fine and like the look of it to, i'm now going to play around with some widgets![]()
Cant answer that, if you read the rest of my post
