Yes it is.
My games also load faster.
What games be they?
I don't know any games yet that makes use of 6 cores.
What games be they?
I'll be looking to replace my Mobo/CPU/RAM soon since it's only a dual core [email protected] but it's kept me going for a long while and was very cheap.
What I'll be interested in is if AMD can get an 8 core CPU out at circa £130 that overclocks well, if that is the case then I'll be investing in a BD chip as soon as the dust has settled. I'd imagine that the Mobo's are going to be reasonably priced too, don't mind spending £100 but anything beyond that just isn't worth it for me personally. Only problem then is I'll have SATA600 and then want to finally purchase an a new gen SSD!
Oh I can see this is going to be an expensive Q2 2011 for my poor wallet.![]()
I just thought I should post this.
Someone over at guru3d has posted supposedly real AMD Bulldozer Preview Benches.
I`m not sure how trustworthy the source is though and if these are really real.
http://forums.guru3d.com/showthread.php?p=3890256#post3890256
I would want to know exactly what model of BD they are using in those tests....
If its an 8 core BD (which i assume it is), then those scores are what id hope for when compared to current 4/6 core models TBH.....
According to the the guys post, the preview benches are of AMD's Zambezi ''Bulldozer'' processor.
Yes it is.
Here's a tip:
Benchmarks will come out at launch.
If anything shows up before launch, look to my blog. If we have not specifically released anything through my blog, then it is not an official AMD benchmark.
Assume nothing prior to launch and watch my blog. All of the other details are not generally worth the pixels they are written with.
AMD will not leak details, so if you see a chart, you should know it did not come from us. If we are going to actually put data out, you will see it in my blog first.
Period.
