- 23 Nov 2004
looking into buying a road bike, got about 600 to 650 to spend on a bike. Had a look at the specialized allez in their store.
I've not got a clue over the groupsets available for road bikes, the allez comes with a shimano 2300 I think, I take it this is their entry level set? what is the next one up?
There is a Bianchi available on evans cycles in 57cm (I'm just about 6 foot tall) looks a bit of a bargain if it fits
http://www.evanscycles.com/products/bianchi/via-nirone-7-xenon-2010-road-bike-ec021257
Look any good?
Advice and pointers would be very appreciated.
cheers
2300 is the bottom of the range shimano so I'd try and get at least sora(newest model) to get 9speed.
I'd look into the Felt Z100,Felt F95, Cannondale Caad8 sora double/triple or the Cannondale Synapse sora triple.
The Z100 and Synapse will have a more upright and comfortable position then the F95 and Caad8.
The Felts run microshift STIs which you like or you don't, they do have a reassuring clunk to them in my opinion. Shifting is done using two seperate levers whereas shimano shifts up using the full brake lever as a shift lever.
Cannondales will be running shimano Stis but run a FSA chainset rather than a two piece shimano but I doubt there is much in it other than the shimano lasting a little longer.
Shimano goes 2300(8 speed) > Sora(9speed)>Tiagra(9speed)>105(10speed)>Ultegra(10speed)>Dura ace(10speed).
To get 105 on a bike your looking at ~£1k.
