Your Pc fails with the new GFX card because all of a sudden it's fitment has increased Loads on the PSU , Loads on the Cpu and motherboard and thermal loads on everything.
Lot's of people fall into the same trap...It was fine before, card is "bricked" RMA
In Your case the chances of all 3 cards being "bricked" is next to impossible !
What we know thus far is it's the motherboard/settings or PSU not coping with full load, we have to assume the GFX card is OK
More so than the exact same card that was fitted before hand?
Wow, Now that's the bombshell, Why did You not mention it ?
I like most assumed it was a new card replaced twice !
next to, but not impossible. Hence why I came to the forums looking for some suggestions as to how to single out a decent testing method that would actually pinpoint whether the GFX is definitely duff or not. Baring in mind that I bought the original card Xmas 2009, and that the replacement was issued in April, and thus there being a fair amount of time between cards. (The first being considerably different to the others)
Totally fair point. Had You shared all the information in the first place !
Right, so why? I'm not trying to argue, its just that so far all you've done is said "Do this.... Do that...." and I've no real idea as to what for.
...Why were You doing 10 passes of memtest, Why did Overclockers tell you to do so ? If all you had changed was to a replacement Identical card which was fine with the system.
JAKUS seriously dude, everyone appreciates your help, but the guy obviously needs help and not you to call him a kid, if you cant handle his questions, would you kindly stfu.
Firenze, good luck. Feel sorry you got this issue.
I just read back a couple of My short reply posts... Your right they can be taken the wrong way
I basically don't know weather to laugh or cry...Why were You doing 10 passes of memtest, Why did Overclockers tell you to do so ? If all you had changed was to a replacement Identical card which was fine with the system.
Here's the rub, I'm now speculating that something changed in the PC "miraculously, or otherwise) that started the chain, and a good chance the original GFX card was fine.. but that's history.
Regarding the "do this, do that" I would not have approached the fault finding any differently with more information on the problems history and I'm sure I always tell people why i would try testing this or that....normally
When you have Your own business You kinda learn to read between the lines with customers problems
Anyway is it all ok now ?
Not really. Battlefield no longer crashes to desktop like it did, but there is still flashes of artifacting on the screen as it changes map. I'm worried that there is something still wrong somewhere in the system and that it is going to get worse, or even take other components with it if it does...
Any suggestions?
cranked up the core and memory by 50/50 seemed alright, then bugged a little as usual when changing maps, then corrupted textures in the next map, and caused the computer to crash when I tried to exit the game..
*shoots self*
I've had the exact same thing with a XFX card that I recently had back after an RMA, it wont run at stock clocks, all my research has suggested that it needs more volts, prolly a bad batch of cards. I'm quite fed up of of the 5870 too, had problems with XFX, never going to buy that brand again
Currently the only way I can keep the GPU stable is to underclock to 825mhz on the core...I should just RMA it again, as it wont run at its default clock and advertised speed
nothing, just frustrated.
Just literally tried a game of battlefield with some friends, all on stock settings etc, and the hung completely on the map change, no flicker of artifacting or anything, just screen froze, audio on a horrible noise and system became completely unresponsive.
So although I thought it was at least better after sorting the CPU volts a bit, it appears its not.
I'll be honest, I've no idea how long the CPU has been running at 1.5v, I've never had any issues, and haven't played with it really, the CPU was a prize at i32, and I built the rest of the PC to hold it.
Got to visit Sheffield on Wednesday for a job interview, so I'll try and see a friend and try it in their PC and see if it works... If it does, its upgrade time, if not, its RMA time.
do memtest
, GPU fluctuation is a min of 0.95V to 1.16V,
