ok so both mates forgot to bring their towers for me to test the card in a different PC... Joy.
I'm very wary of playing with volts tbh, could do with a little advice?
Any other suggestions at this point?
Thanks
I've been had some friends over for a bit of a celebration this weekend, so haven't done any thing since underclocking the CPU and GPU in turn...
Like I say I'm wary, mainly because I've no real experience in playing with the volts. What are the areas I should test? and by how much?
Currently I'm running a Memtest suggested by OCUK, on its 3rd pass atm, still no errors. Quite confident its not a memory issue myself...
well we underclocked the CPU to like 1.2 GHz, and the problem went away, and the volts and temps were normal, then set it back to stock and underclocked the GPU by 250MHz and the results were the same. I set both back to stock, and the problem came back...
Doing a memtest as although I'm sure it'll be fine, I want to run 10 passes just to be 100%.
What a plonker !, see Your post re results..then My reply, You edited Your post to NOW say the problem "remains"
ok Memtest is nearly done, what run do you want me to do on Prime95? (there's like 3 isn't there?) will make sure its priority 1 in the morning.
the VCore is at 1.408v but there's little jumps to 1.424v...
What ?? why ? that is way high...I suggest You load bios setup defaults and do some googling on overclocking and stability testing for Your motherboard setup.
I said up the Front side bus 50mhz , I don't know what the Multiplier is on that cpu of the top of My head, 8.5-9.5 ? well the FSB x the multi gives the CPU frequency, problem is most motherboards automatically ramp the voltage when you increase speeds ( makes it hard to test stability if the goal posts move)
I'm assuming You are still at school ? do You have any smart mates to help you ?
It sounds like a simple problem but without the familiarity with high end PC's and their settings it's gonna be tough for You to nail down and Me to help.
Hmm an interesting result.
while my CPU is underclocked, the issue appears to have disappeared. Only one level change tried so far. takes a while for people to finish the game lol. second change was fine too..
voltages seem to stay within .02V of min and max on the Mobo, GPU fluctuation is a min of 0.95V to 1.16V, though I'm assuming thats just going from being in the game to not... Does this point to anything in particular then?
I've had the exact same thing with a XFX card that I recently had back after an RMA, it wont run at stock clocks, all my research has suggested that it needs more volts, prolly a bad batch of cards. I'm quite fed up of of the 5870 too, had problems with XFX, never going to buy that brand again
Currently the only way I can keep the GPU stable is to underclock to 825mhz on the core...I should just RMA it again, as it wont run at its default clock and advertised speed
I said "DEFAULT" which is blend
OK, I appreciate the help you've provided, but the condescending tone is definitely not appreciated.
I've never played with the voltage specifically as I've pointed out before, I did up the FSB as you suggested, and provided the results. Reading on a review site (the first after googling) they put the volts up to 1.45v to maintain an OC past 3.55Ghz, so doesn't seem like its that mental. Also, why would it be the issue under load, we've already looked at the volts under the issue, and they were fine? I've never played with the volts at all, so why would it suddenly become the problem when I've replaced the graphics card? especially when its with the same card?
