5870 going insane. And taking me with it!
event logs show graphics drivers crashing and resetting at the times when I have been testing. Have tried older drivers (10.4) and still getting the issue.
Would the event logs be enough Proof for OCUK to accept an RMA. I can't seem to cause issue in the tests they would normally run really
I doubt they would to be honest.
http://www.youtube.com/watch?v=i7iBskfsx98
The issue.
CPU Clocks are at stock.
Surely if something else was to blame, I would have had the same issue 3 times, not 3 different issues each time? And why is it that when I've RMA'd OCUK have tested and found issue with the cards I've sent back, meaning they're faulty?
All temps have been monitored and have been safe, GFX never gets above 76C, CPU usually gets to about 30C
If I'm not giving you enough information to go on, I apologise, not entirely sure what info to give, all you have to do is ask!
I'm not on the beta with steam, its odd as I've not done anything different with Steam than when I was on my 2nd card, and that never had this issue...
going to try in a mate's PC tonight, don't have one here at home and I'm kinda in the middle of nowhere.
I've had the suspicion that it might be something on the motherboard myself, but I don't know what I could do to test it. Really hoping its not also because it would mean most of my PC now surely?
Do they still sell motherboards that would take my QX6850 and DDR2 RAM?
the "G" range appear to all be mATX, and that "P" thats available would be be a DDR3 board... I have fought the upgrade itch for as long as I have been able to, scratching lightly, by upgrading just the graphics card (Although it meant a new case I quickly found).. It may be time...
The issue.
The reason I suggest slowing the CPU is to reduce the workload on everything else.
Just underclock by setting the FSB to 133 or something and test.
Something is falling over under load, FULL system load not individual component load.
Download and run CPUZ hardware monitor, it will record max and min voltages
Hmm an interesting result.
while my CPU is underclocked, the issue appears to have disappeared. Only one level change tried so far. takes a while for people to finish the game lol. second change was fine too..
voltages seem to stay within .02V of min and max on the Mobo, GPU fluctuation is a min of 0.95V to 1.16V, though I'm assuming thats just going from being in the game to not... Does this point to anything in particular then?
Right so it's one of 2 things heat or power related,
Just the regular hardware monitor will be ok.....what results did you get ?
Gpu temp min 32C, max 59C. CPU temp, 35 mins, 45~ max
I've reset the CPU to stock, and set the GPU to 600MHz,
Volts end up the same
Temps are about the same,
issue appears to have not returned..
Resetting both to stock, once again volts and temps seem normal, but the issue has returned.
Going to have to play around with my mates system when he arrives and see what happens in there...
Try a little more voltage on the Cpu , then chipset voltage etc.. and then memory volts and timimgs
