GeForce GTX 590 Key Features Revealed
The median price of the gtx 580s as sold by ocuk is £411. If the gtx 590 is two gtx 580s in sli basically it will cost £411 times 2 plus whatever premium nvidia sees fit to charge. This card will cost upwards of £800.
what review was that?
Anandtech
http://www.anandtech.com/show/4209/amds-radeon-hd-6990-the-new-single-card-king/18
Amd requested that sites do the tests first before taking the cooler off to take pictures of the bare card due to the fact they were using phase change thermal compound. Its pretty obvious from the results that anandtech got that they took the card apart and reassembled it with regular TIM leading to the higher temps that ramped the fan way up.
Nvidia have refined their cooling and fan technology with the 500 cards, I expect the 590 to be way quieter than the 6990, maybe even cooler. AMD has got lazy with their cooler designs, same generic style releases after release, Nvidia take things like SLI in to considering and lower the fan to let the cards on top in SLI breathe, it's little things like this that set Nvidia and AMD apart.
Anandtech
According to Overclock3D, he tested the card with the stock tim before he removed the cooler, his conclusion was it's all marketing bull and he actually got lower temps with a different tim applied to the cores.
Funny that since the gtx295 single pcb cooler looks to have the same fan size and mounting method as the 590...
What are you babbling about? :confused:
Slow this morning? notice how the AMD have a flat shroud, in crossfire the lower cards fan hardly get room to breathe, Nvida have lowerd the part of the shroud where the fan is so it can get more air, simple as that.
Yea just like the gtx480 compared to the 5870 lol stop talking rubbish. The gtx280 was also way louder than the 4870 so your nvidia take cooling into consideration is looking pretty stupid. For 2 generations of gpu nvidia have had the louder cards.
They have done well with the gtx5xx but they had to if they wanted to sell cards as they were getting a bad rep for being to hot and loud.
As for overclock3d you mean the guy that sticks the mic straight on the card. You have a very short memory raven he also said the same about your gtx480 which you claim is not loud. Remember all the videos of the gtx480 sounding like a jet taking off.
Did he get 77db out of it like anandtech did? Even guru 3d didn't have many complaints about the fan sound. You're also missing the point where oc3d mentioned they had thermal shutdowns, which could have something to do with the tim used. I also don't see in their review on their site where they mention changing the compound.
Yeah by about 2mm, im sure that will greatly enhance the cooling by vast multiples of degrees...
Fact is 6990 is hot and loud, majority of reviews shows this and it's down to the awful fan design, willing to take bets that the 590 is cooler and quieter.
Overclock3D editor posted it on his youtube channel.
Yeah thats BS mate. I tested the cards and made vids before stripping down. If anything they were cooler after. The GTX480 tried the same thing, its just a cop out for the manus when they know the cards get hot. Any decent TIM like MX4 or NH-1 ect will outperform the gunk they use from the factory.
Its just to stop nubs who dont know what they are doing using something basic or **** like arctic silver.
TimeToLiveCustoms
Every little thing helps.
Selective memory appears to be a great asset. :)
I'll be very surprised if it comes with effectively 1.5gb. They felt the need to release a 3gb 580 so if anything needs more than 1.5gb its the 590!
Fact is 6990 has is hot and loud, majority of reviews shows this and it's down to the awful fan design, willing to take bets that the 590 is cooler and quieter.
It will obviously run hot due to the fact it has 2 gpu's on board plus 4 gigs of ram. 89c at load seems to be about the max temps for regular gaming with things like furmark obviously pushing it hotter, thus making the fan louder.
1.5gb per gpu?
Fail. Was hoping for 3gb. Doesn't make sense to release a card built for 30"/surround gaming and then give it only 1.5gb of memory, It's too easy to hit the limit.
With the power of two underclocked 580's on tap there's going to be quite a bit of gpu horsepower avaliable so hilarious levels of aa are more than ever, feasible options. I quite enjoy cod4 with 32xaa/8x SS, fps count is fine but I near 1.3gb at 1920x1200.
Oh and to those complaining about noise. Go and buy a passive 3650 or something. Do you really think that two of the fastest cores made by each company on a single pcb sharing a single fan are going to be cool, quiet or sip power?
This basically sums it up. People are expecting to much especially from a stock design.
True. Very true.
It's just that non-references do so friggin' well that it makes you wonder if they're intentionally just hitting the 'just enough' line to give their card partners a greater marketing spill.
"45% cooler than stock" sounds better than "20% cooler".
1.5gb per gpu?
Same as with 580 reference SLI, I don't see people complaining about lack of Vram there, surround gaming is such a niche market it's not important to Nvidia.
