Awesome build. Loving the colour scheme. Ram looks sweet too.
The fans you are using, are they these http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-XG&groupid=701&catid=57&subcat=4
If so, how quiet / noisy are they? What about the amount of air.
they are the fans you linked yes
they push a lot of air at full speed but they are a bit noisy
i run the fan controller at just over a third of the way to max speed on all 6 fans
this keeps them running very quiet and means the LEDs arent too bright.
they still push a good amount of air and keep the system cool.
the past week i have been running the system with the front fans [on the double radiator] switched off. the temps are around the same as they were before [ambients have dropped quite a bit]
seems to be working well and cuts down on a bit more noise too
the system is so quiet i dont know its on half the time
- thanks for the kind comments above too
