- 8 Dec 2002
- North Yorkshire
Should be included in your data bundle, if not yes. google your providers apn. I.e Google T-MobileAPN
Is it ok to root and chuck a custom rom on these phones if they are carrier locked? I've done loads to mine but it's unlocked.
Done a google on it and nothing is conclusive thanks in advance
If by carrier locked, you mean the handset can't connect to other networks with the appropriate SIM card in, yes. My phone is locked to 3 but I've got Voodoo kernel and Darky's 9.3 on there.
I'm on pay as you go. I tried looking for the correct settings but nothings working. OH WELL.
It's very easy to unlock the SGS
http://devicehelp.vodafone.co.uk/fi...ng/i9000 Galaxy S/SamsungGalaxySi9000_WEB.pdf
This should help even if you're not on Voda. Just search for the substitute APN codes
Thank you! This worked.. this will cost me though, right? Per minute etc..
Didn't need to myself but few options including Market apps.Which method would you recommend? I already have root since I'm on a custom ROM. efs is backed up etc.
Any of yout guys give darky 10.0 3 beta a try?
Thinking it might be worth a try, downloading it now and just backing everything up.
I've not, but please let me know how you get on.
Cheers
Thought his 9.xx was final final release?
Confirmed JVK is the Official Samsung 2.3.3 releaseBeing leaked as we speak.
