***THE NEW KING - GTX 590 IS HERE!***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The new King has arrived, the formiddable GTX 590 which boast so much raw processing power there is no card more powerful and has superb overclocking abilities whilst keeping noise levels low. This card is the *NEW* Supreme Master:-
Asus GeForce GTX 590 OC 3072MB GDDR5 PCI-Express Graphics Card @ £629.99 inc VAT
The most powerful NVIDIA® graphics card ever created with a dual-GPU model offers unmitigated gaming performance for hardcore enthusiasts
The Asus ENGTX590/3DIS/3GD5, the world’s fastest dual-core NVIDIA® graphics card, aimed directly at PC gaming and entertainment enthusiasts. Featuring 3GB of GDDR5 video memory and a core clocked at 612MHz, the card also comes with ASUS Voltage Tweak overvolting for up to 50%* faster clock speeds at 918MHz, this represents very noticeable enhancements to in-game smoothness and responsiveness. Twin NVIDIA® GF110 cores bring the full potential of Fermi technology to bear on DirectX® 11 and 3D Vision™ Surround gaming in uncompromising detail, quality and can easily handle full HD 3D output simultaneously on three displays. The GTX 590 also offers more than double the power of the GTX 580 thanks to two GPUs running in 2-way SLI™ on one board by default.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 612 MHz
- CUDA Cores: 1024
- Memory Clock: 3420MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 3yr Warranty
Only £629.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card with FREE Gaming Mouse @ £666.66 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
The GIGABYTE M8000Xtreme is a super powerful weapon designed specially for gamers. Equipped with 6000dpi pro-laser engine supports high-speed movement and accurate precision. The onboard GHOSTTM Engine memory is capable of 45 button assignments with macro editing and storing customizable macros that lets you bring your unique settings wherever you go - use them on other PCs without software. The Advanced GHOSTTM Engine software allows gamers to record and edit their
desired scripts which can include complicated keyboard and mouse commands. The Introduction
design concept of the GHOSTTM Engine software is Avatar system based, just like in games. Its Ultra-user-friendlyTM drag and drop structure user interface plus powerful macros on the go will equip any gamer to be competitive in the heat of battle.
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- 3yr Warranty
Only £666.66 inc VAT.
ORDER NOW
MSI GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card @ £614.99 inc VAT
- CUDA Cores: 1024
- 2yr Warranty
Only £614.99 inc VAT.
ORDER NOW
Limited stock in initial waves + demand from early adopters = charge what you want.
Fact is stock will run dry in all likeliness so count your lucky stars (should you want one) that the prices are reasonable, period.
I could never understand why people thought the 590 and 6990 would effect the single gpu card prices like the 580 :confused:
Reviews up on guru3d.
I'm pleasantly surprised with it. Power consumption is only about 60-70 watts more than my 580 at full load.
I can laugh now at all the fanboys who said it would be crazy loud and produce ridiculous amounts of heat as it is actually very good on both those parts. It's cooler than the 6990 and much quieter under load.
Just a shame about the price but I did expect it :)
TBH, I expected it to be faster than a 6990 though...
True, the performance is a bit depressing and unlike the 570/580 there isn't much room for overclocking.
Both the 6990 and the 590 have their drawbacks, and with the 480/6950 so cheap, you'd be better served getting one of those multi gpu setups instead.
this card has apparrent pro's and cons to the 6990, though if I were inclined to chose i'd get the 6990 and stick it under water. IMO massively improved crossfire scaling is nvidia's deadly enemy
