Cards are dying at stock as well, so IMO even modest overclocks could greatly increase the risk of premature BANG even without touching the voltage.
I was optimistic about these dual 512 cuda core cards from Nvidia, but the weak clock speeds and instant explosions is seriously horrible.
As for people thinking that 1.2v is too much for GFX cards, erm no, its not. The last couple of generations from both Nvidia and ATI have supported up to 1.15 - 1.2v overvolting within the bios. Even if the max recommended voltage is 1.15v, there is no way that just going 0.05v over that limit would cause such an instant explosion unless theres a fault with the card, otherwise every single GFX card and CPU I've ever owned should have died as soon as I tried overclocking them.
Personally I expected a recall by now from seeing how Intel responded with SB, especially because a card getting that hot and popping presents a fire hazard surely???
Wahey, exciting quote from a review: Card blew up during testing
Up til then I was merely under the impression that they were faster than the 6990 in some things but nothing amazing while at the same time being quieter. Which about sums up why they'd be released at 6990 prices being second out and all.
Someone been skimping on the cooling to make it quieter then![]()
Card blew up during testing, power limiting system does not work reliably
Don't forget guys that the worst noise for the 6990 comes in Furmark which 99% of review sites tested with powertune unlimited and the OC bios(rightly I might add), however most also tested the 590gtx in furmark with the furmark limit in place.
They mention the following:
IMPORTANT: The supplied Geforce Drivers 267.52 for Geforce GTX 590 will not stop the card from overheating when overclocking. Please use newer versions from the Nvidia website and stay away from 267.52. Otherwise this may happen ...
Nvidia were right all along, you only get realistic smoke effects with an Nvidia card
@ straxusii
Not really much louder then.
53db is like having a card that is 75% quieter than a card that is >70db like what Anandtech reported.
