you could give the settings and ICC profile a try from the calibrated TFTCentral review here. worth a go![]()
No audio cable with mine either...only just realised![]()
Quick question - my C version didn't come with audio cable - based on TFT Central review, C should come with audio cable, right?
I just loaded up your ICC profile, now the screen looks much more like my half-calibrated Dell 2209WA did
Should I keep brightness at maximum setting? I feel that anything less is too dark with this profile.
Ditto.
Mine didn't come with any audio cables either.
i'm guessing this was dropped in the final stock.
brightness should only impact the luminance so you can have that set at whatever you feel is comfortable![]()
I have upped my Hazro HZ27WC Monitor Calibrated Color Profile on mediafire for those that would like to try it.
For the brightness setting for this color Profile, I turned down the brightness on the screen as far as it could go and i`m sure I up it either 2 or 3 times.
http://www.mediafire.com/?edj6mcdesdpdflp
Do you use any software to load the colour profile or just Color Management in Win 7?
So basically there's no other settings I need to mess around with but load the profile with Windows Color Management tool?
Do you happen to know if I need to have any third party software running in the background for games to recognize the ICC profile?
Well I'm not giving up just yet with my HZ27WC. I've nearly got the perfect monitor. I don't have any dead pixels that much I know, just a couple of really, really small bits of dust in the top left and bottom right (top left is slightly more noticable).
Are they really noticeable in normal use?
Unless you are in a hermetically sealed environment you are going to have more than two bits of dust settled on the front of the glass all the time. You wouldn't be able to clean them off fast enough not to have.
If you can remove the glass you would have to be very careful when you wipe away the two bits of dust underneath not to introduce more yet more dust, there is dust floating around everywhere even out doors.
Removing the glass is not advised but it can be done with perseverance and patience. Without access to a clean room, the results may not be satisfactory.Come on Hazro tell me what I need to do to take the glass off!
