What exactly is this 99% bug?
Basically where a gpu jumps to 99% at idle, or during no apparent stressful work.
I found a fix for it that worked for me, uninstall the drivers, then reinstall just the driver, ccc and application profiles without the hardware acceleration bug
Now works fine, just waiting for AMD to fix the damn 50-60% low fps issue
(where each gpu is at 60% but i get low fps, lower than with 1 card)
