the 480 SE is now £250 !!!!
BS
Edit: Just seen the price and you're right!!!
It's the same price as the SOC
BS
Im not telling porkies well mines still artefacting ...
but use of their 8 pin converter seems possibly to make thing marginally better but may be wrong
I bumped volts up to 1.088 and it ran at 800 in OCCT for 400 seconds with no errors - which is probably good enough and near enough to advertised to stop worrying really - ok its higher than the 1.037 - but making do may be better than new PSU or replacing card etc etc - as after all it could be my PSU
ok just installed this card and after playing crysis warhead and crysis 2 ive noticed slight flickerings all over the screen.
will try another driver version and run occt as i think its artifacting![]()
going to say i cannot get mine to hi 80c in games 74 or 78 is the highest i have seen
i knew i should have plumped for the 570. this oc is obviously pushing the card to much.
im unsure as how to test with occt? what settings should i use. do i just run it at full screen with error check?
if so it started throwing up errors almost immediately.
im running 2 separate rails into it each with a 36A rating so im dont think its my psu.
i just wanna downclock the gpu for final testing.
ok down clocking the core to 750 and the memory to 1850 and it runs fine on occt.
this is going back. faulty or DSR? if under dsr do i state the card is also faulty?
There's just too many cases of faulty cards now, OC have my card today so i guess i will find out next week if faulty, i will get a refund if that is the case. but i'm guessing i'm going to be 2 way postage out of pocket!
why two way?
I had to pay to send it to them, and if found not faulty i have to pay for the return aswell mate.
