- 1 Apr 2009
Good build
fit the I/O shield plate, a good firm push will see it click into place.
then look at the mounting holes in the motherboard, add a standoff to the motherboard tray in the case to line up with each hole.
fit the ram, cpu and cooler to the motherboard and place the it into the case, double check that all the ports are free from obstruction because the I/O shield plate has little bits of metal that can get in the way.
add a screw throught the board and into the standoff for each hole.
only if there is a hole in the motherboard in the same location.
Ok, thanks. I'm on the HDD now.
Another bag came with the case with a label saying 'For 2.5 HDD'. The HDD I have is a 3.5 so do I need these?
There are only 4 screws and 4 rubber things and there are 3 holes a side on the HDD.
Thanks.
